Rear Steats Installation
Discussion in 'Civic and CRX - EF' started by kmoallem, Nov 24, 2006.
  1. kmoallem
    kmoallem New Member
    Hello,
    I just got rear seats shipped from Europe for my '89 CRX. I’m planning on installing them this weekend … it looks like a no-brainer … but I was wandering if anybody has any advice for me before I begin. It looks like I have all the parts that I need.
    Many thanks in advance
    ../kaveh
  2. eg6sir
    simple bolt in... nothing you really need to know.. its 2 bolts at the most
  3. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    Well blanco, remember that CRX's in the states don't come with back seats... so you have to bolt in the mount brackets to install JDM or EDM seats.
    It should be very straightforward.
    However, don't some models of rex's come without threaded bolt hole provisions for rear-seat installation? I know I've read that somewhere....
  4. hondacrxb16vtec
    hondacrxb16vtec New Member
    lemoore, califoria
    it's a very simple process. should only take 10-20 minutes. i've done it 5 times. you will need to drill two holes for your seat belts. be careful the gas tank is under neath. and don't make the holes to big. everything else is easy. if you want some pics send me a pm with your email and i'll give you some step by step.
    maybe i'll even type it up for everyone else. that would be good.
  5. eg6sir
    none of the USDM CRXs came with back seats.. just that nifty little storage area
  6. Andrew
    Tallahassee, FL
    For Mr. Blanco-
    USDM- no back seats.
    JDM-
    EDM-
    CDM- back seats
    basically
    J, E, and CDM > America.
  7. kmoallem
    kmoallem New Member
    Actually Canadian CRXs didn't come with back seats either (I live in Canada) .... as far as I know, the only difference between the CDM and USDM CRX is that the Canadian version has a metric speedometer.
    Thanks for all the input guys ^_^
  8. CRXSIWANNABE
    CRXSIWANNABE New Member
    Backseats for crx
    could seats from a civic for example fit in a crx???? just curious if you would really need to special order a seat or not
  9. eg6sir
    back from the dead.. and start your own thread... bringing up old threads to threadjack will just get you flamed
  10. hope801
    hope801 Active Member
    also the Canadian crx's came with lights that stayed on in the day too.:ph34r:
  11. kmoallem
    kmoallem New Member
    really!
    not on my crx ... but then again I have a '89 ... maybe that's the case with the 90-91's.
  12. 92civicb18b1
    92civicb18b1 The Trisexual
    Look at the date buddy.
    Again, bringing a thread back from the dead. This is the second time someone is bringing this thread back
