Rebuild while I wait for the Swap?
Discussion in 'Civic and del Sol - EG and EK' started by stauron, Oct 11, 2015.
  1. stauron
    stauron New Member
    93 canadian civic si (D16Z6) 546,120 KM on original engine
    I'm planning on saving up for a GSR swap.
    In the meantime my poor tired engine is going through a ridiculous amount of oil. Mostly not from bad seals.
    So, do you all reckon that it is cheaper and more efficient to try to replace the rings and whatever else I find or just buy oil by the barrel until I'm ready for the swap. I'm hoping to get everything together for the swap by spring/summer 2017.
  2. Briansol
    Id say just find a block. z6 are cheap. Probably $100 on cl or a junk yard. Rebuild will cost you more and needs to be done right with hone and ring seat etc...
    Jeef likes this.
  3. stauron
    stauron New Member
    That is an option I hadn't considered. I will look. I'm sure to find one with 25% the miles that will curtail my oil use by at least 100 bucks too.
    Thanks
