Recommended ECUs
Discussion in 'ECU's, Electronics, and Tuning' started by imgolo, Aug 30, 2018.
  1. imgolo
    imgolo New Member
    Hello.
    I have an EM1 that runs on a chipped P28, appears the previous owner whom restored it had deleted the emission components - evap, o2s.. now I need to get it to pass emission. ISO any suggestion and recommendation to pass. Thanks in advance.
  2. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    lawl ..... well he didnt have them "deleted" ..... he probably just removed them and the ecu im sure is throwing a CEL and wants the data...... the ecu NEEDS O2's to make correct adjustments with A/F etc , as far as the evap system ? no telling what he has done im sure its just everything unhooked/removed , the chipped p28 has NOTHING TO DO WITH THE SITUATION , 1996+ has to have a ecu with no cel codes and a catalytic converter to pass emissions, can become quite costly to make it pass if somebodys done a bunch of shit
  3. Briansol
    yeah, try to find a stock p2t from a 99-00 si. they are around. but, it depends what else has been done to the car that might require the chipped mod basis. Is it mostly stock?
    https://www.ebay.com/bhp/p2t-ecu
