checked belt with gun...
you check IGNITION timing with a gun...
what did he do to adjust it? did he rotate the distributor? or did he move the crank vs cam gears to set the motor back in time ie: cam to crank timing, aka when the valves open in relation to where the pistons are in their travel...
do you have a compressor?
turn and lost compression have nothing to do with one another unless he was low on oil and scored the cylinder walls...
i'd suggest a compression test before a leak down test...
compression tester is cheaper and no need for a compressor...
are you sure you don't have the wires mixed up?
you need a leak down tester and a compressor...this leakdown test... where can i get it done? My brother left to califorinia for 7 days and he told he was done with this piece of crap...so much for family.
The fellow I bought this car from says that it happened a when he was taking turn nothing too special just a turn. After that the car wouldn't idle properly and the he suspected lost compression in one of the cylinders. The car drives alright when its hitting 3thousand RPM but has trouble in the lower RPMS.
are you sure the wires and plugs are good for those 2 cylinders??Also we started the car with two cylinders and it idled fine. However as soon we stuck the other too back the car was having up and down idles...
