Returned from the Dyno *UPDATE DYNO SHEETS*
Discussion in 'General Tech and Maintenance' started by khai_tuan_nguyen, Feb 20, 2005.
  1. khai_tuan_nguyen
    khai_tuan_nguyen Senior Member
    Setups
    B20b block GE sleeved bored to 85mm
    b16 head with type r internals
    JDM type r header
    Greddy exhaust
    str 68mm tb and cam gears
    injen CAI
    AEBS intake manifold
    AEM fuel rain and regulator
    hondatas s100
    Here are the numbers
    235 hp at 7500 rpm
    177.8 ft-lbs torque at 6000 rpm
    Pictures of the car and the power curves to come once i have scanned them in
    HOLY shit is what the guy had the say. They thought their machine was messed up. They checked everything out and it was fine. They never saw a setup put down so much power. For reference i am in oregon and it was a mustang dyno.
  2. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    holy shit! Nice #'s dude! :thumbsup:
  3. Bl6CRX
    Bl6CRX Senior Member
    UCLA
    What compression/pistons are you running?
  4. driver1
    driver1 Senior Member
    wow very nice #'s dude
  5. erebunicrx
    erebunicrx my name is Dale
    Bristol ct
    i think something was wrong. post some more about the build. on a mustang dyno too? but if it was right nice #'s
  6. BigJ
    Wow, That's amazing! You should be pumped!
  7. GSRCRXsi
    MD
    yes i would like to know what compression you are running as well. something doesnt seem right. you should be limited by the head. but if all is well and true then good job.
  8. khai_tuan_nguyen
    11.5:1 wiseco coated pistons
    What else about the build.... umm don't relly know what else to say. It was right, because they had the person who maintains the dyno out there checking everything, from sensors to correction factors. Ask me more questions and i will answer them. I will have dyno charts up by tomorrow hopefully.
  9. khai_tuan_nguyen
    IT runs on 92 octane and it it is +1 on the intake. It took the guy about 5 hours to tune.
    Khai
  10. phunky.buddha
    Dallas / Fort Worth, TX
  11. pissedoffsol
    no way in hell is that acurate.
    type R cams and 11.5:1?
    your power level is at that of sunk stage 3's and 13:1 compression.
    their dyno is wrong.
    i'd HIGHLY suggest going to another dyno and just do a couple pulls to verify it.
  12. highperboi
    highperboi Senior Member
    Alameda, California
    wth that is amazing. does it feel like it has 235 power?? my friend with 2.0L gsr and toda C with around 12.8 compression only makes 205.
  13. khai_tuan_nguyen
    WEll I don't know what to tell you guys. If If someone wants to give me money i can verify these results. These people do the best work. They are more expensive, but they are very good. They are the only hondata certified dealer in oregon. They are the olny ones i let touch my car. I really don't know what to tell you guys. That is the numbers i got. I did over 20 pulls and it made good pwoer throughout. What could make the dyno give higher numbers? Its not like it was the first time they used it nor is it the first car they have dynoed. They have dynoed literally 1000s of cars. They have a company 1200 hp supra and a 800 hp civic. I don't know if it feels like a 235 hp vs a 200 hp car since i have not felt what it those numbers feel like, but it is damn quick. I hit 60 in second in like 4 or less seconds.
    Khai
  14. Cashizslick
    whats the name of the company?
    do u have their phone #?
  15. khai_tuan_nguyen
    Yeah why?
  16. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    Something isn't right. I put 201whp and 151tq with Skunk stage 2's and 12.5:1 compression on an 85mm gsr block with an LS crank and other shit....
    I'd go find another dyno.
  17. pissedoffsol
    theres a shit load of mustang dynos in OR.
    http://www.mustangdyne.com/LocatorPages/DynLoc_OR.htm
    in fact, go to the #1 choice in your state--
    http://www.groundzeromotorsports.com/
    I'm SO positive that your results are wrong,
    that if you go there, to ground zero, do 3 pulls, and make within 2-3 hp of what you show above, I WILL PERSONALLY COVER YOUR DYNO FEES FOR MAKING YOU GO BACK.
    When you come home with lesser numbers, I will not re-imberse you. :)
    ground zero knows their shit. If i was remotely close to their shop, i would go there.
    give them a call. make an appointment.
    (503)256-FAST
    prove me wrong, prove that those numbers are real, and i'll pay the 75 bucks for the 3 pulls.
  18. YouKnowWhoIBee
    YouKnowWhoIBee my avatar is better.
    Maryland
  19. phunky.buddha
  20. khai_tuan_nguyen
    Alright sol,
    Guess what?
    I absolutely agree with you that Groundzero knows their shit. It actually costs $175 for the first hour and $125 for each hour after. Guess what else? I persoanlly know them and their owners. Guess what else? They are the only certified hondata distributors in Oregon. Guess what else? They have a mustang dyno. Guess what else? THAT IS WHERE I GOT MY DYNO!!!!!!
