b20 inspired
im in the process of building my b20/vtec and i have a questions. for pistons im using je with around 9 to 1 compression. im using the stock crank and rods. i havent found any rod or main bolts for that motor. does anybody make any. will ls bolts work. would it be ok to use the stock bolts for around 9 to 10 psi. thanks for ur help
