seat question
Discussion in 'Civic and del Sol - EG and EK' started by rustbucket, Jun 18, 2011.
  1. rustbucket
    rustbucket New Member
    after reading online that dc teg seats bolt up to eg civics, i went to the junkyard and pulled the front seats from a 94 teg, vacuumed / steam cleaned them, and dyed them black. when i go to bolt them up the two outside bolts go in fine, but the bolts wont go in on the inner side, the holes are too high - is there something im missing or did the junkyard mislabel the teg?
  2. eg6sir
    these seats will bolt right in
    these wont
  3. RHDism
    RHDism Right Hand Drive guru
    That DA is F'n Schweit! :worthy:
  4. jdmJynks
    jdmJynks New Member
    what teg seats will fit in a EK?
  5. rustbucket
    thanks man but the reason i dont know if its a da or dc is because the body panels are stripped off at the yard, i had to go by the year painted on the window. said 94, which would be dc unless it was one of the last DAs made or the junkyard fucked up. here's pics: [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  6. rustbucket
    what a mess, dont see an edit button though. you can see how high the rear inner hole is on my drivers seat, i can fit my fingers underneath it. even if i got a longer bolt it would never be flush with the floor. the front inner side is a little better, looks like if i wiggle it around a bit i might be able to make it fit
  7. Korax
    Korax New Member
    Western PA
    You can't edit until you are out of greenhorn status.
  8. eg6sir
    hard to say.. they both had a similar design.. i'm guessing they're DA seats .. swap the rails from your civic seats
  9. eg6sir
    another reason i think they're DA seats is because DCs didnt come w/ solid color cloth seats that i know of.. thought they all had some sort of design in them
  10. eg6sir
  11. rustbucket
    They did have a pattern, I just dyed my whole interior + the seats. Must've been a late 93 model sold as a 94. Thanks for all your help brother, ill google around on how to swap rails
  12. Korax
    Korax New Member
    Western PA
    Should be able to just cut the rings and swap the whole pan.
  13. eg6sir
    swapping rails is easy
  14. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    yeah i have swapped rails on several sets of seats, takes about 10 minutes a seat. those are definitely DA seats.
