sohcslammer
Other than the pistons, rods, valve springs and retainers, what do I need for a rebuild? Oh, yeah, and cam of course. Right now I have picked out the Crower titainum valve-spring/retainer set, Zex cam # 59300, and DOHC ZC pistons/rods. Thanx to some great inside info I am told I wil get about 12.3:1 cr with this setup. Can I still run pump gas? (Supreme obviously) What else do I need? I was going to go with the vennom IM too. Any info would be apreciated... Can I bore the cylinders .30 over and still use the pitons? What ECU should I use? Is there a better cam or spring/retainer set I could use? Right now, this is a VERY low buck setup... about $650 without the manifold. Thanx in advance -
Shadney
Shadney
