ok i have the integra harness on the car and the car isnt cranking but my ecu is telling me code 16 for injectors my question is with the harness i have what wiring needs to be done?!?
you will need to wire all the injectors to a resistor box, then the box to the ecu, and a few more. There is a diagram on this site under swap articles called DPFI to MPFI write-up that we used on a 1990 4-door jdm B20 swap and it worked perfect.
