swap or no swap?
Discussion in 'HYBRID -> EG-EK / DC' started by soto2635, Feb 23, 2008.
  1. soto2635
    soto2635 New Member
    got a 95 LS it has 130,xxx miles on it and its a auto. i want to make more power and make it a 5 speed and put on a turbo . im debating this
    1) b18c1 complete swap - about 3g's
    2) keep the motor i got the b18b build the internal and just buy a turbo and 5 speed swap
    3)do the ls-vtec with 5 speed swap and turbo.
    which approch would you guys go with? any suggestion wll help thanks in advace
  2. 92civicb18b1
    92civicb18b1 The Trisexual
    Auto to manual and a LS-Turbo.
    I would suggest a rebuild though, and might as well upgrade the internals while you're in there.
    I made 253hp with my LST and was very satisfied
  3. soto2635
    soto2635 New Member
    yea i was kidda leaning towards that but i wanted people's input before i did anything
    what's a good tranny to go with? and for internal?
  4. Matts96HB
    Matts96HB . Moderator VIP
    A good tranny to go with is the GSR.
    You might wanna consider aftermarket or oem LSD if you're going turbo.
    BTW the LS is a great platform for forced induction.
  5. soto2635
    soto2635 New Member
    i guess i under estimated my engine then, i really thought its was a crappy engine
  6. 92civicb18b1
    GSR is the best trans to go with.
    A lot of people despise the LS because of it's lack of Vtec, people seem to insist variable valve timing is necessary in every 4 cyl. application.
    I couldn't suggest internals unless you suggested a power goal and what you'd like to do with it.... ie: NA or FI
  7. soto2635
    soto2635 New Member
    im thinking of goin ls-t, i want to push at least 230 or some nothing crazy but something to show people up in. wouldnt the LS tranny be better for turbo?
  8. 92civicb18b1
    No, I used it but I wouldn't recommend it. Shorter is always better unless you're looking for top speed.
    230 hp is extremely easy tp obtain, even on a stock motor.
  9. soto2635
    soto2635 New Member
    what are some parts u recommend for internal building?
    what type of pistons etc?
  10. Matts96HB
    Leave the internals stock, theres no reason to mess with em for that power goal.
    Get a properly sized turbo for your goal, and build it right the first time with quality parts. Piece together your own kit, its alot easier to do it right. Pre made kits are not tailored to your specific application.
  11. soto2635
    soto2635 New Member
    the reason i say that is b/c of the high mileage i dont want to leave it as it currently is and have it blow on me later
