swapin a d14 engine with a b16
Discussion in 'HYBRID -> EG-EK / DC' started by scoobay, Sep 20, 2007.
  1. scoobay
    scoobay New Member
    I would like some info about doing this can anyone help me out on this matter
    the model of the car is 96 honda civic hatch ek.......
  2. toqeer1986
    toqeer1986 New Member
    just swap the engines thats all use existing wiring or use the wiring with the b16 engine they should match up the same should have no probs with that same tranny and all mounts evrything should bolt on
  3. scoobay
    scoobay New Member
    i wud love for that to happen i got my fingers crosss i thought i had to buy different mounts, axles everything
  4. Dark93DX
    Dark93DX New Member
    B.C.
  5. scoobay
    scoobay New Member
    d14 is a 1400cc\16v sohc and non vtec engine that come with the 96 honda civic out of the uk
    Engines
    u can get all te info of every engine eva manufactured by honda from the web site
  6. Dark93DX
    Dark93DX New Member
    B.C.
    Interesting, never new honda made any engines smaller than 1.5L in the 90's.
  7. toqeer1986
    lolz well here in the uk there are a few i mean i had a 1.3 civic dx hatch on a 1994 plate 1300cc engine suprised ? lolz
  8. toqeer1986
    as i was saying axels mounts they should all be the same even the gearbox well i fink ur existing tranny would mate just fyn the only prob with the uk spec 96 civic d16 engine tranny is the gears are tooo long and you wont be able to have fun unless its lyk evry 2 mins when you change the gears lolzzzzz
  9. toqeer1986
    check my b18c4 swap slide pics you can see what i've dont lolz well what i've put in but to put in a B series engine u gotta change the tranny axels mounts and should come with the engine oh and not to 4get the shift linkages lolz
  10. awptickes
    MD
    I wouldn't be so quick on that one. I have a d14z1 and d14z2 (the difference being a restrictor plate in the thottle body) and that site makes no mention of either, much less any ODB2 engine smaller than 1.5.
    I've found that most "Complete Honda Engine Guides" make no mention of euro-spec engine, it makes it a little harder to do a mini-me on one. ;)
  11. toqeer1986
    well im my civic 95 lsi i had a d15b7 i just changed the engine to a d16y7 and evryfin ran perfect with the d15b7 ecu no difference apart frm more power and quicker acceleration than the d15b7
  12. scoobay
    scoobay New Member
    that b18c4 mussi get up in the number quite fast
    i jus hope this swap i lookin to do, dont be nuff stress
    so u tell me the only thing i gain got to do is worry bout the shift linkages
  13. toqeer1986
    you shift linkages should be ok coz i had my d16 on a s20 tranny which was perfect so you dont need to worry about anything really
  14. Matts96HB
    Matts96HB . Moderator VIP
    Ok, enough of the misinformation.
    NO your d-series tranny will not work with a b16.
    You'll need a b-series tranny. On top of that, heres a list of other stuff you'll need.
    T-Bracket from 99-00 Si
    Driver side upper mount from 99-00 Si
    B-Series shift linkage
    B16 ECU
    You'll need to run a wire for the vtec solenoid, and knock sensor I believe
    Throttle cable will most likely need to be changed, or the mounting bracket altered. I had to do that with mine. Anyway, do some searching. You will learn alot. Good luck.
  15. toqeer1986
    sorry thort he was on about d16 lolz my bad matts rite
  16. Matts96HB
    Oh yeah, at first glance thats what I thought too. :p
