tach install
Discussion in 'Civic and CRX - EF' started by crazymark01, Jul 11, 2007.
  1. crazymark01
    crazymark01 New Member
    im trying to install a aftermarket tach in my 89 crx si and i cant figure out what wire to splice the green wire that will give me the proper rpm, can someone that has installed a aftermarket tach help me out. thanks
  2. crazymark01
    can anybody help me??
  3. jlicrx
    jlicrx Senior Member
    Colorado Springs
    the blue wire from the 2-wire connector at the distributor is the tach signal wire
  4. crazymark01
    what wire is it when it plugs into the ecu
  5. jlicrx
    Colorado Springs
    it doesn't go to the ECU - the blue wire runs from the distributor to the gauge cluster
  6. crazymark01
    oooooh ok thanks alot for the info, i have it spliced up to the orange wire that goes into the ecu. i feel like a retard, lol
