Tech level 10
Tools needed
Window cleaner
Paper towels, or newspaper
First you start by cleaning the application surface....
Next you want to carefully choose location, as this will determine final output power...
Then careful remove the JDM rear panel to expose the high performance adhesive
Once you have the locatoio secured and prepped, carefully line up the exterior location, and hte HPA side, and apply, using several pounds of pressure in a back and forth motion over the non stick side of the panel.
Once it is in place, carefully peel back the HPA film...
Now sit back and wait for the ladies to flock to you jock...
Tools needed
Window cleaner
