Time Has Come To Get Serious About D16y8 Cylinder Head Rebuild
Discussion in 'Engine Building' started by 89' Project Civic, Aug 23, 2009.
  1. 89' Project Civic
    89' Project Civic d16a6/d16y8 "mini-me"
    St. Catharines, Ontario, Canada
    Ok, here is the speel about what I have currently done engine wise. I have rebuilt my D16a6 block with all new:
    -OEM pistons
    -OEM wrist pins
    -OEM gasket set
    -OEM oil pan, because my old one had a lot of larger pin-holes in it!
    -OEM thrust washers
    -NASCAR true-circle piston rings
    -Clevite main/rod bearings
    -Royal Purple synthetic engine rebuild lube, I will be using synthetic engine oil (I am not sure on which company though), and I know this will be really expensive but I plan to keep this engine top notch for racing.
    FUTURE PLANS FOR D16a6 BLOCK:
    -ARP mixed (D16a6/D16y8) head stud kit
    -OEM 3-ply D16y8 head gasket
    Now, onto the D16y8 cylinder head. I had the head somewhat OEM rebuilt, by myself, with new parts such as:
    -OEM valve stem seals
    -OEM (VTEC) solenoid seal
    -VISION 5-way adjustable cam gear
    LEFT UN-DONE:
    -Valve stems
    -Valve seats
    -Valve spring retainers
    -Camshaft
    *The following information refers to the cylinder head COMPLETELY apart*
    I am going to be doing a racing application. My plans are as follows:
    -Crower "stage 2" camshaft
    -(not sure what brand, please help fill this spot!) "stage 2" valve keepers
    -(not sure what brand, please help fill this spot!) "stage 2" valve retainers
    -(not sure what brand, please help fill this spot!) "stage 2" valve springs
    -(not sure what brand, please help fill this spot!) "stage 2" valve stems, if needed
    -Cast iron turbo, d-series, exhaust manifold
    -Port and polish, then flow benched
    -Skunk2 intake manifold with B-series 70mm throttle body
    That is pretty much it for my speel.
