tranny for boost!
Discussion in 'HYBRID -> ED-EF / DA' started by icoy22, Nov 11, 2006.
  1. icoy22
    icoy22 Junior Member
    so I'm planning to turbo my car but was wondering what tranny would be best for boost. I'm thinking the gsr but I'm not sure. this would be on a ls or b20
  2. 5thgenb20
    5thgenb20 New Member
    i've read somewhere on here that the LS trans is the best way to go with turbo because of the long gear strides. however, i've also read it's the weakest trans and will eventually fail under high power. i guess it depends on what your deifinition of high power is.
    i'm doing a b20 swap right now on my 93 dx, and i 'm running the LS trans. i want to go turbo soon but only 7 lbs. so i hope the LS will last.
  3. MaXXuS
    MaXXuS New Member
    LS trans is the best for exactly what you said, long gears. Isn't 6-8lbs just fine on a non-built motor? I have even heard of people running 10lbs on a stock b16 and having no problems.
  4. oopma
    oopma New Member
    go with an LS or a ys1 92-93 gsr
  5. icoy22
    yeah there was guy around here with a turbo ls with 9 psi with a good tune I gues he ran 12.4 stock internals but his motor blew I don't know how long it lasted him
  6. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    go with the ls 92-93 gsr tranny is to short geared
  7. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
