Tranny Question
Discussion in 'Civic and del Sol - EG and EK' started by 95CivicExMd, Jul 26, 2006.
  1. 95CivicExMd
    95CivicExMd Junior Member
    With the help of pissedoffsol, I know what motor I want to swap in my 95 ex 5 speed (B16a2 SiRII). Now I would like to know if the tranny that comes with this engine has LSD. And if it doesn't would another tranny from a different motor that has LSD would mount to the B16. If I bought a used tranny with LSD and wanted to make sure it lasted for a while, would it be possible to take it to a shop and have them put new gears in it so it would last a while.
  2. Vosty
    Vosty "REP 4 U" Whore Member!!!
    Lower Valley, WA
    I could be wrong... I do think the SiR II engine comes with a tranny that has lsd. Type R trannys have lsd for sure, only prb. is you have to be able to trust who your buying from that it is a typer tranny cause i dont think they have a vin of any sort.. You can always add LSD through Quaife but its expensive close to a grand... Phantom has a cheaper option ive heard mixed reviews on them...They retail around 300 bux i think...
  3. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    If you buy your motor from hmotorsonline.com you can get an LSD tranny for an extra $300.
    Otherwise you can use a Type R transmission or an LSD GSR transmission or any other B series LSD tranny.
    Yes, a shop will replace the gear sets in a transmission, but make sure they replace/inspect the synchros.
  4. boosted rex
    boosted rex Junior Member
    If youre not going to go nuts on the motor then you probably wouldnt need to even mess with the trannys gearing if its a b16 tranny. Kinda sucks hitting vtec in 5th at around 80 though.
  5. 95CivicExMd
    Ah but I do plan on going nuts with my motor lol. I am just tring to get an amount on how much everything is going to cost so I can go talk to the money man to see if I can't get a personal loan. Thaks to everybody that responded.
