Ok I just bought my Acura Integra LS w\ 112k last week. I am now noticing some issues come up. Both problems are completly un-related.
As for the transmission thump.... It can be felt in first\second gear. If I quickly let off the gas I will get a loud thump. The car stays in gear and everything, just a loud thump. I had suspeted mounts, but if it were mounts it woulden't thump in only first and second. Is this my tranny? Is it done or can it be saved by a fluid flush? Could this mean I am simply low on fluid (i believe there is a slight leak). I am MTX btw.
Now as for the stalling.... This only happened twice. I would start the car up and it would immediatly stall out. It woulden't putter out (as if it were starving for fuel), rather it would just completly stall. I would just start it up and everything would run as normal. No codes or anything. I was thinking it could be the Hall Effect pickup sensor because a similar problem happened with a friends truck (his was intermittent stalling). Any ideas to what this could be?
Thanks for any advice given.
