turbo cb7 f22
tsellersjr93
CB7 with vtec gotta love
I just ordered a turbo kit and was looking for some info on it before it gets here, like what i should look out for and what i need that the kit is probably not going to come with and how hard it is to install?
My Kit came with:
JDM'S T3/T4 Turbocharger with 3" Filter
Turbine Turbocharger
Oil cooled only
6 blade propeler
Compressor Specs :
3" Compressor Inlet
3.000" or 76.2mm inducer
1.990"" or 50.55mm Major
Compressor .50 A.R.
Compressor 57 Trim
M24 / T4 Compressor Housing
Turbine Specs :
T3 Type Turbine
11 Blade Type
2.25" Exducer
Turbine .64 A.R.
Turbine 76 Trim
2.567 " or 65.2mm Major
2.207 " or 56.06mm Minor
Exhaust Outlet Flange with 5 bolt design
Can modified to use external or internal wastegate.
Suggested for 1.6L to 2.3L engine up to 150-400HP
You may need to modify some of the intercooler piping to make it fit right. You need bigger injectors, larger fuel pump, and a chipped or tunable ecu with a good tune to make it last. Then I'd start saving up for a decent turbo, as the ebay units are hit and miss.
Yeah, that looks like a cheapy E-Bay kit? Like 99sidude said, I'd replace the turbo with something of better quality. E-Bay turbos are notorious for blowing out their seals.
And honestly, you should have researched this better before you whipped out your credit card and hit "checkout". Why buy something and then afterwards come to a forum and ask "Hey, is this thing I just bought any good?"
The ebay turbo's are hit or miss as stated, BUT I do know of people who have rebuilt theirs with good gasketry, and they are G2G thus far.
well turbo kit was installed and the car ran a 13.8 at track on first run and ran a 29 second run because it blew the motor somewhere around the 8th. i'm just going to scrap this project and put a h22 in the car and call it a day
H22 sounds like a good idea... :thumbsup:
sounds like you didn't have it tuned well. or you didn't check the engine before adding more power.
