Turbo Mini-Me
Discussion in 'Civic and CRX - EF' started by GlassHeadlights, Jan 11, 2010.
  1. GlassHeadlights
    Calgary, AB
    I'm thinking of turbo'n my Mini-Me to 200, maybe 225 whp. I have 4 grand stashed away but I'd like to spend half that.
    So far I have:
    -Rebuilt D16A6 block with 35,000 miles on it
    -Rebuilt D16Z6 head with 2500 miles on it
    -D16Y8 intake manifold
    -OBD1 conversion with chipped P28 ECU
    This is my list...imput is needed here:
    -Walbro 255 fuel pump
    -Vitara pistons
    -Stronger rods (may do Eagle/Vitara set up)
    -Factory bearings
    -Turbo
    -Manifold
    -Injectors
    -MAP (needed?)
    -Wideband O2 (needed?)
    -Spark plugs (needed?)
    -B.O.V.
    -Clutch (stage 2)
    -Stock flywheel
    My thoughts are I will yank my motor out, take off the oil pan, leave the crank in and just change out the rods and pistons. When I did my Mini-Me head swap, 2500 miles ago, the block was really clean (35,000 miles old) with a fresh honed surface. Right now its a 10:1 CR, does anyone know what Vitara pistons will do to that?
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Boost on the stock pistons. Taking them out with the crank in is possible, but barely.
    200whp is a LOT in a CRX. Lots of fun. Keep the turbo small. Need a 14b and a manifold? :)
  3. GlassHeadlights
    Calgary, AB
    Its a 10:1 CR right now though.
    Haha...I took down the thread because within 5 minutes I thought....I like N/A better. :) My buddy just got a 5.0L Mustang and I wanted to spank him. Lol
  4. double0Si
    double0Si ლ(ಠ益ಠლ) VIP
    Columbus, Ohio
    Get a newer moped.
  5. RoughKnight
    RoughKnight Christmas Car
    Ottawa, Ont
    i'll take that 14b off ur hands if u want :D
  6. GlassHeadlights
    Calgary, AB
    I don't understand that expression.
  7. double0Si
    Columbus, Ohio
    Basically,
  8. GlassHeadlights
    Calgary, AB
    Ahhh..I see...funny stuff.
  9. double0Si
    Columbus, Ohio
  10. Matts96HB
    Matts96HB . Moderator VIP
    youre really concerned about beating a 5.0 mustang?
    unless its wildly modified, id say you probably dont have anything to worry about
    NA sucks, go FI ;)
  11. GlassHeadlights
    Calgary, AB
    Oh alright...I'll put the thread back up for discussion.
  12. Ethan
    Ethan Well-Known Member
    huge turbo and lots of nawzzz! you gonna need it cause a stock v8 can beat any pos jap car anyday!
  13. GlassHeadlights
    Calgary, AB
    Haha...yea...
    I've decided to be a trend whore. I'll go B-Series eventually because its JDM.
  14. Ethan
    if i was you id go d....
  15. PhyRe
    PhyRe Senior Member
    ct
    boost the d as is have ur fun rompin on it and with some cash in the stash buy and ls for when the d blows and then slap the mustang kid in the face with the cash u saved. reuse what u can from the kit on the ls and start over
  16. Ethan
    wurd... when it blows and you swap the ls boost that shit! that's my exact plans lmao. and we have the same engine... werd!
  17. GlassHeadlights
    Calgary, AB
    Or just have a reliable B...I dont need a high HP car at 16 years old. :ph34r:
  18. double0Si
    Columbus, Ohio
    Why dont you quit screwing around and drop an LS1 in there. D < B < K < LSX FTW!
  19. GlassHeadlights
    Calgary, AB
    Hahaha...right...that's the best route.
  20. Ethan
