Turbo?
Discussion in 'Forced Induction' started by Jhonda, Feb 6, 2003.
  1. Jhonda
    Jhonda Member
    Arkansas
    i AM BUYING A COMPLETE TURBO KIT OFF A 97 ECLIPSE AND WAS WONDERING IF THEIR IS ANY SPECIFIC INFO I NEED IN DOING THIS IT FOR A 94 DEL SOL SI SOHC VTEC ANY HELP IS APPRECITAED.
  2. Jhonda
    Jhonda Member
    Arkansas
  3. pissedoffsol
    #1- loose the caps. it's real annoying
    #2- try posting in the boost forum =)
    #3- why did you buy an eclipse kit when you have a honda? or is this from an eclipse's stock parts?
    most of the parts can be made to work- but you are going to have to get a different manifold, or jerry rig that one on. I've heard of mitsu manifolds fitting on d-series, but i've never seen it done.
    upgrade that side mount intercooler. its a POS and doesn't fit very well.
    you will also probably need some custom piping, as the eclipse bay is shaped different and backwards from a honda's, so the lengtths are going to be all wrong
