twin turbos
Discussion in 'Forced Induction' started by ej11, May 14, 2005.
  1. ej11
    ej11 Member
    SO CAL!!!
    the comp. housing reads 3AN1.
    the turbo came off a 13b rx7...
    has anyone ever use these to make a custom turbo set--up???
    i have two turbine so was thinking of useing one for a custom set-up(b16a).
    would it fit the dsm turbo ex. manifold with a custom b16a turbo header?
    thanks in advance. :worthy:
  2. swanny
    swanny Senior Member
    buck teeth and government checks, PA
  3. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    If you want big power, go single turbo. There is a reason most of the hardcore drag supras are running sigle turbos. If you are racing you usually don't need (or want) big power until upper RPMs anyway. If you want a car thats for a road course, you should just be staying all motor anyway.
  4. totalburnout
    NJ
    I wouldn't say that...
    Whatever gives you the nicest power/torque curve for the money is what you want if you're on a budget.
  5. pissedoffsol
    i would.
    all motor is the way to go for sub-200 whp or a road/autox course car
    hell, you don't even want to do a basic 240 swap your self :p j/p
  6. preludebuddy
    preludebuddy Senior Member
    putting the rad in colorado
    he said he wanted to use one of these. he doesnt want a twin turbo setup, he wants to know if that turbo will work with the b16.
    you would need a manifold for a b series motor that is flanged for that turbo. i doubt a dsm manifold would work, but i'm not sure that your turbo would even be a good idea for that motor.
  7. pissedoffsol
  8. ej11
    ej11 Member
    SO CAL!!!
    the turbo looks as big as the t25 turbo used on the eclipse...
    and im not looking to use the twin set-up, just one of them...
    so no good for the b16? i will be useing it for road racing.(their in good condition,came off a wrecked 97 rx7).
    thanks...
  9. pissedoffsol
    using "big" and "t25" in the same sentence is an oxy-moron. lol
    lots of oem cars use small turbos-- sr20s, 4g63's and so on... but what you need to understand is that the honda motor is SOOO much more efficient.
    it has a much higher VE and a ton more compression. not to mention the rpm factor.
    a t3 super 60 is about as small as i'd go on a b16. only thing smaller i'd consider is the gt28rs. its a small turbo, but its super effiecient, and has a large a/r making it capable at the top of the honda rpm range as well.
  10. ej11
    ej11 Member
    SO CAL!!!
    thanks man, t3 super 60 got it...
    do know WTF this means "oxy-moron"....
  11. pissedoffsol
    oxymoron is a term used to descibe opposites.
    apartment (they are close together)
    driveway (you park on it)
    parkway (you drive on it)
    and so on...
