v6 integra
Discussion in 'HYBRID -> EG-EK / DC' started by spicer, Mar 31, 2004.
Thread Status:
Not open for further replies.
  1. spicer
    spicer Junior Member
    guys I need some advice. looking to drop a vtec V6 into my 95 integra...what should i put in it, and what trans am i gonna need.
  2. brc80
    brc80 Senior Member
    Southern California
    Anything can be done with enough money, but that being said, i would go with a b series or even an h22 if you want straight line power. But a v6 is going to need alot of work to get it to run in your car.
  3. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    why not just get a 350 small block and mount it tranverse in the car?
    honestly, i have no idea what motor to use, why not get one of the accord V-6 motors- at least it's still a honda, but even then you're more than likely going to have to do some serious cutting, welding and cursing- IMO
    NOT WORTH IT!
  4. mwvnos
    mwvnos Senior Member
    SC
    x1000000000000000000
  5. 97hatch
    97hatch ?
    Anderson IN
    well you could try a acura cl 3.0 vtec v6 if you arr up for a challenge
  6. Slammed90Lude
    milford, PA
  7. H22AdelSol
    H22AdelSol Senior Member
    san diego, california
    do the accord v-6's even come in anything other than automatic?
  8. GSRTURBO
    GSRTURBO Member
    NO, unless you are talking about the newer accord v6 6 spd, good luck getting that sucker to run in an integra :spin:
  9. pissedoffsol
    waste of time and money here.
    other than the brand new accords and nsx, the v6 motors are sohc bastards with junk tranny's.
    you're better off with a 4 cyl.
  10. Projectzc
    Projectzc Senior Member
    Can you say custom. My suggestion drop a v6 in the back of you teg use a domestick tranny some fabrication will be needed with enough deditcation you can doo it. I have often though about droping one in the back of a CRX that or a NSX motor. .lots o research will be nessasary. hope your good at math
  11. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
  12. 90crxb18
    90crxb18 Senior Member
    lake elsinore cali
    saw one somewhere before... a red CRX with a rear mounted NSX motor. dont know if it ran or not, but it looked pretty nice!!
  13. spicer
    yeah i can weld and have a shop, i was thinking about a transverse 3.0l but the trans was what i was really worried about i can fab a driveshaft and set up some rear gears easily enough...am i going to have to have the ecu custom built? basically i want to have a bad ass integra to blow the doors off all the pretenders out here in eastern canada, money, time or skill shouldnt be a problem, so if you've got some really wild ideas, let me know
  14. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Even if you have the money/time/skill to do this the question still remains why? It seems to me that it would easier/cheaper to build a kit car with your choice of 6 cyl than to install it in an Integra. Something many people seem to forget is that innovative and unique does not imply wild or crazy (or stupid or silly).
  15. brian11to1
    brian11to1 Senior Member
    Going along with what LSVTEC said, why dude, why? Dont waste a good car, build a complete custom car, frame and all.
    Ive got a little project in mind for myself when i start my own business, the company car:
    90-97 Prelude
    F20C S2K engine cusotm drive shafte, S2K rear suspension etc. I like it
  16. word
    word Senior Member
    the red CRX with a NSX motor is by mahdavi motorsports here in GA, they just stuck the engine in the rear, its a RR. www.mahdavimotorsports.com
    i dont think mounting the engine in the rear and making it a RR is what you want. if you have enought money (A LOT of it) you can consider dropping the NSX motor in the civic in FF format, that way you can use the NSX tranny. Check out Signal's NSX civic drag car, http://www.superstreetonline.com/featuredv.../130_0303_chop/
    imo, bad idea. you can build a 2.3 B series turbo'ed that'll make more power with the money and able to use available aftermarket parts.
    chris
  17. word
    word Senior Member
    oh wait your car is an integra. in that case mounting in the rear would pretty much be out of the question, that leaves you with the option of the nsx motor.
  18. reckedracing
    reckedracing TTIWWOP VIP
    NY
    i really wonder where these noobs come from...?!?!??!!
  19. Slammed90Lude
    milford, PA
  20. reckedracing
    NY
    ah, that explains it...
Thread Status:
