Vtec Help
Discussion in 'Civic and CRX - EF' started by Ky'sCRX, Oct 18, 2006.
  1. Ky'sCRX
    Ky'sCRX New Member
    Shepherdsville, Ky
    i had a del sol with a sohc vtec and now i have a 89 crx wit a b16. how do i know if the vtec is working right. it seems to me in my sol i can feel when vtec hits and in the crx i dont feel it. any help would be great.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    well if you cant feel it no worries but can you hear it change over,
  3. Ky'sCRX
    Ky'sCRX New Member
    Shepherdsville, Ky
    not really it seems to stay the same all the way to redline
  4. AHHVTEC
    Alabama
    well in a b series you should hear it very well it may not be working
  5. Ky'sCRX
    Ky'sCRX New Member
    Shepherdsville, Ky
    how many wires should be hooked up the the vtec silenoid, what might be the problem
  6. AHHVTEC
    Alabama
    well the one wire going to the selnoid its self you can tap into it with the car off and touch the hot post on the battery to see if it makes a clicking noise
  7. Ky'sCRX
    Ky'sCRX New Member
    Shepherdsville, Ky
    unhook it and touch it to the battery post
  8. Ky'sCRX
    Ky'sCRX New Member
    Shepherdsville, Ky
    and also my rev limter is a 7000 do i need a chip to get it higher
  9. AHHVTEC
    Alabama
    well yea you can do it that way just run a straight wire from the selinoid to the hot post but just touch it a few times to hear it click dont just hold it on there
  10. Ky'sCRX
    Ky'sCRX New Member
    Shepherdsville, Ky
  11. <CRX>
    <CRX> Guest
    hey if you say that you have a b16 and you say that your rev limiter is 7000 then most likely your vtec isnt working because it happened to me in my b16 crx when i pinned the ecu i switched the vtec oil pressure and the selinoid make sure that you have those two pinned right in the ecu and make sure you oil pressure is grounded after i had everything right it was hitting and my rev was 82
  12. Ky'sCRX
    Ky'sCRX New Member
    Shepherdsville, Ky
    i will check it out
  13. Ky'sCRX
    Ky'sCRX New Member
    Shepherdsville, Ky
    what do you when oil pressure grounded
  14. Ky'sCRX
    Ky'sCRX New Member
    Shepherdsville, Ky
    <CRX> thats what it was. it works great know but it still stops at 7 grand
  15. ef8
    ef8 Junior Member
    what ecu do you have?
  16. Ky'sCRX
    Ky'sCRX New Member
    Shepherdsville, Ky
  17. d15kid
    d15kid New Member
    Lakeville Ohio
    so i have a 93 civic with a d15b..is it worth it to put a d16 vtec on it?
  18. anarchiaetpax
    anarchiaetpax Junior Member
    Make a separte post for this, it has absolutely nothing to do with the topic.
