What Can I Expect?
Discussion in 'HYBRID -> EG-EK / DC' started by 1sikef, May 3, 2009.
  1. 1sikef
    1sikef New Member
    1994 CX Hatchback
    - Stock K20z1 (210hp)
    - Hybrid Racing Fuel Rail Mated To Aeromotive Regulator
    - Stage 2 Exedy Clutch (Solid Disk) w/ 12lb Flywheel
    - Aem Intake w/ Filter
    - K-Pro ECU
    What Do You Think I Will Run With 93oct. On Slicks
    Does Anyone Else Have A Similar Set Up That Can Tell Me What They Ran 1/4
  2. phyregod
    phyregod !!YTINASNI
    Central Texas
    mid 14s?
    Depends alot on the driver.. and if you're listing off fuel rails and regulators as things that might affect your ET on a stock motor, I'll assume you arent experienced.
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    if you can drive 12s
  4. 1sikef
    1sikef New Member
    no im experienced ive been messing with hondas for 10 years i just listed what i had done and to see what other people ran with similar set-ups because im waiting on my header before i take it to the track and im no stranger to the track, this is my first k-swap, so i was justr seeing about what i can expect
  5. nootrac22
    exeter pa
    :rolleyes:
  6. Dark93DX
    Dark93DX New Member
    B.C.
    I agree, 12's if you can drive, also elevation is a factor to.
    The biggest gains on that stock K20z1 are coming from Kpro, it does alot for the k-series. what exhaust are size are you running? 2.5", 3"?
  7. autox 89 dx
    autox 89 dx Member
    SF bay area
    I was at the track last wednsday and ran againts a 95 coupe full interior and he ran a 13.3 with alot of wheel hop with a K20
  8. That Honda
    That Honda New Member
    Yeh
    Uhm for a hatch it depends on weight imo and based on you're driving you could run mid 14's high 13's if you have good shifts. If you gut the seats and you take power steering out and you're just making a track car, gut everything and take AC out power steering etc. Nothing neccessary for a track car.
    Best of luck.
  9. AHHVTEC
    Alabama
    well it being a cx its very lite weight. if he cant hit 12s he is not doing it right lol
  10. 1sikef
    1sikef New Member
    yeah i took of the a/c and power steering, and it is a cx very light, and im running a 3in thermal r&d catback
  11. intenseneal
    intenseneal New Member
    Well I would say mid to low 13s to start. It is a new setup and you dont know how it will run on the track. You may need to work out a few bugs in the begining. Just saying that cause people build a 12 second car then it runs slower than it should on paper and get disapointed. I would be bringing a helmet and fire gear to the track when you runn for sure, it will be a fast car. With slicks be sure to have good axles or you will break them.
