What can i swap too, i blew the stock one!
Discussion in 'HYBRID -> ED-EF / DA' started by sodomizer, May 4, 2006.
  1. sodomizer
    sodomizer Junior Member
    Hi, i have a 91 civic si with the D16 16 valv SOHC 1.6L. My girlfriend was driving it on very low oil for a few months, and now when i take the spark plugs out there dripping with oil. No dout the bottom end, and most likely valve train will need tremendous work. I want to swap to anything really. I dont want to rebuild, and I dont care about power. Just looking for soemthing that I can find out here in alberta canada.
    Thanks!
  2. redhothondacrx
    redhothondacrx Junior Member
    oil soaked plugs?probally because of leaky spark plug tube seals.buy a new set of valve cover gaskets
    NAPA part number VS50300.it comes with tube seals.low oil pressure would not cause oil to leak on plugs.
    over time heat and petroleum makes these seals hard and will let oil pass on top of the plugs.change the seals and problem will be solved.....
  3. sodomizer
    I dont think it is a gasket problem. I went to start it this morning and I could hear pieces clicking arround as it turned over. When i took my valve cover off the seals looked okay. But they are most likely leaking too.
  4. mikes89civicstd
    mikes89civicstd Junior Member
    I'll be happy to take the d16 head off your hands along with the inatke manifold, tranny and ecu if you are not going to use it. My civic needs a new head and my 4-spd tranny sucks. And i'd love to experiment with the MPFI system. Maybe we can arrange something...
    thanks and good luck
  5. reckedracing
    reckedracing TTIWWOP VIP
    NY
    i would suggest a stock replacement for you...
    perhaps a Z6 swap on a budget
    the bottom of the spark plug is covered in oil right? not the top?
