what kinda work am i looking at
Discussion in 'HYBRID -> ED-EF / DA' started by zaneithan, Feb 5, 2004.
  1. zaneithan
    zaneithan Senior Member
    im assuming it will bolt right up to the mounts i have, is there any wiring other then vtec?
  2. Jeef
    Jeef NO MA'AM Moderator VIP
    Pretty much bolt in, except you keep your drivers side mount L bracket from your original engine. You use your tranny, or other 4th gen tranny. The wiring will depend on the obd you want to run.
  3. zaneithan
    what OBD would be best for it? i believe its OBD 1 isnt it?
  4. d16X
    d16X Member
    yea u run obd 1 i had the same swap in my 90 hf. it was pretty quick for the price
  5. 2fastaccord
    2fastaccord Senior Member
    I highly reccommend wiring to obd1. Not as bad of a swap as most people think. You will be running with 99-00 Civic Si's neck and neck.
    Peace*
  6. zaneithan
    so basically all i would have to do is run some vtec wiring right? or is there more involved?
  7. Jeef
    There is more involved. You will have to get a conversion harness from obd0-obd1, add a 4wire o2 sensor, use the z6 fuel injectors and distrbituor, and do some wiring. Its worth it.
  8. zaneithan
    thanx all, gotta put more thought into it, i can get the engine with 90k miles, new timing belt and water pump,wiring harness and 5 speed ecu for 300$ just gotta decide if i wanna do it or not
  9. d16X
    d16X Member
    get it man they are pretty quick in crx's mine was beatin 99-00 si's and hangin beside stock gsr's
