Turbo LS is your best bet. Get the engine from www.hmotorsonline.com ( Buy me one while your at it)
because they have the best reputation for good engines. LS is the strongest honda engine in your range, and the best for boost ( Considering you are using mostly stock components ). It has the largest bore of all the 1.8 engines and therefore will produce the most torque as well as plenty of horsepower. (Torque = very very good). 7.5 PSI with minor tuning and 10 PSI with lots of tuning, with stock components. This will be a fast setup. One of the main downsides to this engine is the cylinder head, it flows wayy less air than a VTEC head. I strongly recommend Turbo profile camshafts, valvesprings and retainters. ( Crower makes good ones..)
and at least do a Mild Port & Polish on the cylinder head. To be honest with you I wouldnt push more than 8 PSI on a regular basis and 10 PSI only when you really gotta go fast.... Good luck!
