Why the Click???
Discussion in 'Civic and del Sol - EG and EK' started by craiger, Aug 28, 2008.
  1. craiger
    craiger New Member
    Austin, Texas
    I have had this problem with other Honda's in the past but right now I am working with a 94 civic ex and in order to start it I have to turn the key to the on position with all the dash lights on then when I hear the click I crank the motor and it starts. If I don't do it this way it will not start and acts like it is not getting any fuel.
    Any Ideas???
  2. newb
    newb phresh VIP
    Backwoods Northwest
    Is it the main relay?
  3. dacheat
    dacheat ..is grounded.
    strongbadia
    yeah the fuel pump needs to do its thing before you can start the car. the main relay tells the fuel pump to do its thing. if the main relay or the fuel pump aren't functioning at 100% you have to wait for the click or replace the parts ;).
  4. craiger
    craiger New Member
    Austin, Texas
    Thanks DaCheat.
    Where is the main relay at? Maybe on the kick panel drivers side? What does it look like?
  5. delsol88
    delsol88 Blinker Fluid Specialist
    JC,MO
    i believe most of the relays are under the hood. i could be wrong tho
  6. dacheat
    strongbadia
    main relay is inside under the dash behind the fuse box. you can search for 'main relay' as there are lots of threads regarding this part, and find pictures and more questions/answers about 'em.
    look at the 2nd pic in this post to see where the main relay is and what it looks like:
    http://hondaswap.com/civic-crx-ef/weird-idle-141477/#post1038068
  7. craiger
    craiger New Member
    Austin, Texas
    Thanks Dacheat. The picture really helped me find it with no problem. Is it just a main relay or a fuel main relay? OK where would you suggest getting this part for cheap? I know I can get it at the dealer, and the salvage yards around me but is there any aftermarket new ones made? Thanks again!
  8. dacheat
    strongbadia
    it's called both; if you were ordering it i'd say main fuel relay but confirm the thing they're trying to sell you looks right. check around online, but i don't know of any aftermarket new ones.
    glad the pic helped. :)
  9. George777
    George777 ^^ Likes Bewbies
    With your mom
    Sometimes you can find them at a Napa or Foreign Auto Part for significantly cheaper than a dealership. Might be worth a shot.
  10. craiger
    craiger New Member
    Austin, Texas
    Thanks for the ideas guys. FYI, there are several for sale on Ebay. I will also try Napa.
  11. dacheat
    strongbadia
    fyi the ones on ebay, unless guaranteed, may have the same issue as the one you're having problems with. :D
  12. craiger
    craiger New Member
    Austin, Texas
    I thought about that, you're right on that one. I would only buy new. Thanks.
