wont start
Discussion in 'Integra' started by crayzrooster, Aug 16, 2008.
  1. crayzrooster
    crayzrooster New Member
    virgina
    Ijust bought a 90 integra iv had it about a weak ran fine started right up and every thing .Now today I go to leave and it wont start ,I checked the battery ,the ignition switch, the starter,neutural safty switch,tryed to jump the starter across and toke it out and checked it it works out of the car off of the battery and it still wont start the only way it will start is to drift start it and pop the clutch Im stumped I dont know anything else to do and I checked all the fuses can anybody please help ?!
  2. Justin66
    Justin66 The Hondaswap Canadian
    Peterborough, Ontario
    does your fuel pump turn on? You can hear in when you turn the key to on (not start). Just so you know. Cause if its not spark its fuel.
  3. salvadorrivas13
    salvadorrivas13 New Member
    San Jose CA
    check your dizzy, main fuel relay, and the fuel pressure. does are common problems on integras ^_^
  4. crayzrooster
    virgina
    I can hear the injectors prime when I turn the key but it just wont turn the starter over for nothin I think its something with the starter circit it runs fine if you drift start it Im stumped
  5. 94H_Ex
    94H_Ex Under employed
    Florida
    hmmm i ve heard of this problem alot. could be a short in your wire harness. or your ignition switch
    most people just hook up a push button or push switch to the starter. with the starter in. take a wire and hook it to your positive post on your battery and with the other end, hit it to your starter's remote wire ma thingy (cant remember the name). if it starts fine then theres something with your ignition switch. if you dont understand me. tell me. i ll post pics.
  6. efhondakid
    Akron-Canton, Ohio
    My GFs Sol did the same thing, I ran a wire from the postive on the batery to a switch and cut the black w/ white striped wire on the starter to the same switch. turn the key on, hit the button and it starts. I couldnt figure it out, no blown fuses, starter works, so I just rigged it.:D
  7. George777
    George777 ^^ Likes Bewbies
    With your mom
    My buddies VW did that. We installed a push button start on it and it would fire up every time. He eventually had it fixed, and the shop told him that the wires were shot and it couldn't carry enough current to start the car or something like that.
  8. efhondakid
    Akron-Canton, Ohio
    I figure it has a short in the starter circuit or something to that extent, it was easier to run the switch than break out the multimeter an chase wires.:D
  9. cruzing10
    cruzing10 New Member
    peg city
    bro i still dont understand/????
  10. George777
    With your mom
    Three months late...
