WTT: 88 Mitsubishi starion
Discussion in 'Vehicles: For Sale/Trade/Wanted' started by needavtec, May 28, 2007.
  1. needavtec
    needavtec New Member
    i have an 88 mitsubshi starion for sale/trade. looking to trade for a crx with an engine swap, but may consider other trades. starion has 73,000 origional miles, 30,000 on engine build
    Performance mods:
    Forged engine, Race prepped rods, wiseco 8-1 pistons, Iron ductile top rings, plasma/ceramic coating on rings and pistons, MLS head gasket, Non jet valve head, Ported, race single coil springs, Hydraulic lash pumpers, oversize ss valves, and assembled with clevite bearings and arp hardware. The engine was made to handle 7500+ rpm's and high boost levels. (Mostly everything came from Midwest Turbo) http://www.midwestturbo.com/
    The engine is controlled by SDS (simple digital Systems) standalone engine
    management system. It has a hall sensor, crank fired MSD ignition and is completely tuneable form the SDS. The SDS has in car adjustibility and no need for a laptop. With a wideband O2 sensor it does have built in data logging. More information can be found at (http://www.sdsefi.com/)
    The turbo is a BB T3/T4, This turbo is efficient from 15-33 psi. It has been ported and clipped. This is a High power band turbo. It has a Turbonetics manifold and 38mm wastegate. The basic info can be found at http://www.midwestturbo.com/
    The exhasut is a full 3inch with the wastegate dump running into a straight through muffler. It is not quiet and does not have a catalytic converter.
    The intake is a Tubular manifold with a ford 70mm Throttle body. It has a high flow fuel rail and 75# hour injectors. The injectors are fed by a walbro 255 and has #8 fuel lines. The car has an adjustable Fuel pressure regulator controlling the fuel into the fuel rail.
    The power is ran through a 6 puck clutch, with a short shifter and tranny with 42k miles.
    Everything is kept in check from the cockpit with a Pyrometer, sds mixture meter, boost gauge and Monster tach. The factory gauges and the SDS hand held unit monitor everything else so you know the exact engine temp, air temp, duty cycle etc.
    The battery was relocated to the hatch and is powered up by an optima yellow top battery.
    The car is kept on the ground with tokico's in the rear and shp's in the front. It has a 3 point brace on the front towers and also a rear strut bar. It has slotted rotors and newer pads to slow everything down.
    for those who don't know the stock engine is a 2.6L turbo and also has a LSD stock.
    Tell me what you got!!
  2. tofasttoslowforyou
    tofasttoslowforyou New Member
    i have a 92 gsr black with a b17a1 motor and trans and has 60k on motor rebuild and 237 on body, no rust, no damage mint inside and out and its a 5 spd best thing its been bone stock no mods, never modded virgin
  3. needavtec
  4. formby
    formby learning in progress
  5. needavtec
  6. tofasttoslowforyou
    or instead of the gsr i have a 91 awd tsi , 5k on new motor less than 3k on tranny, 50 trim 650 injectors palm pilot, safc apexi, 30x8x3 front mount chiped eprom ecu 2600 clutch, poted mani o2 housing, and full 3in turbo back exhaust alot of other new stuff lmk
  7. needavtec
    send me pics of both. Forged internals in the tsi?
  8. needavtec
    sorry for the mistake, the engine build has 10,000 on the rebuild not 30,000.... also the car is making 425rwhp. looking to trade for really any honda. make me an offer.
  9. needavtec
  10. tofasttoslowforyou
    91 awd talon 50 trim, front mount everything needed to run 11's in 1/4 mile the only reason i am selling my baby cause i am going to the army in less than a month and there is no point in parking it and paying storage fees for 4 years on it cause i just got it running after it sitting for 2 years and i have dumped a good penny on this car
    open for trades but no pos
    4k or best offer
    91 talon tsi awd
    5spd
    6 bolt 4 bolt combo
    50 trim turbo
    adjustible wastegate
    eprom ecu chiped for the 2g maf and 650 injectors
    1 year old on the new stock suspension
    front mount with 2.5 in piping
    crushed bov
    650 injectors
    metal head gaskit
    motor was rebuild less than 4k
    tranny was rebuild 4k
    has fpr and an stainless steel lines and fittings
    act 2600 clutch
    no sunroof
    no ac or power steering
    new water pump with maybe 10 miles on it
    ported 2g mani
    3in turbo back exhaust with magna flow muffler
    walboro 255 in tank with rewire to it
    apexi safc2 wired and ready to go
    palm pilot wired ready to go
    new tires on the wheels with maybe 200 miles on them
    2 slim fans
    new radiator hose lower and upper
    2g maf
    i am sure there is more parts but i dont remember
    the only problem with the car is
    -rear seats and headliner needs to be put back in
    -front fender and hood got primered cause of the paint fade
    -car will need timming belt replaced soon as it is showing some wear on belt
    -car sat for 1-2 years before now and now i got it back to great shape i now have to go back into the army
    - car does have some rust from sitting so long but is all minor and nothing major
    car runs and drives great runs 20 psi any day no problems
    car should run 11's as it sits
    no joy riders or people that wants shits and giggles
    i need to leave for the army in less than month so anyone that wants my baby come and get it
    this is my ad on other site interested lmk
  11. tofasttoslowforyou
    also will come with 3 boxes of parts for this car
  12. needavtec
    i am really looking for a honda with a swap, sorry. no one has a honda they want to trade for a 425rwhp starion?
  13. tofasttoslowforyou
    no very doughtful if you cant find someone and it has been a month
  14. goldgreen90ef
    goldgreen90ef goldgeen90ef
    cold ohio
    bump for this car...sorry to much power for my cracker ass... but a sweet rare whip....gl with sale...
  15. tofasttoslowforyou
    why are you trying to get rid of it
  16. needavtec
    looking to buy a honda...
  17. 91SwappedHatch
    91SwappedHatch New Member
    Hagerstown
    Thanks for calling and nice car look on autotrader...cragislist..ebaymotors.....and just email them i got one of my cars from a guy who was trying to sell his honda on ebay so just send a email on any of those web sites and you never no.....good luck man
  18. SHOGUNOVDDRK
    SHOGUNOVDDRK New Member
    australia
    lol people in australia would kill for that car ^_^
  19. dveit
    dveit Well-Known Member VIP
    DMV
  20. goldgreen90ef
    cold ohio
    there was pics on that link before....
