Hey i swapped a b16a intoo my crx then scored a civic which is real tidy but had a fire so put the b16a in too tha civic..and found a auto zc tidy as and put that in my crx re wired the ecu back to normal using insulation tape tho? but its throwing codes 6,9 and 10? has a little bit of a bog b4 it gets up in the revs?
also after sitting for few hours it wont start properly? other then that seems to run algood when its warm? exept for after a bit of 5 min drive the revs start going up and down when ur idling? like from 900ish rpm bak to 1500ish? but u just turn it of and restart it and that goes away
