97DXcoupe
GSR Swapped/Gutted
Christ dude, create your own fucking thread![]()
all jokes aside, .. he was just asking if i knew anything or could help.
heres the latest news.. i think i have RESOLVED the issue.:worthyp:
The problem (or so i have been told) is that the axles i got sent, yes they were NEW... but they are not OEM.
what's the difference you ask??
OEM axles have the rubber dampers on them, aftermarket (99% of them at least) do NOT have the damper..
i took my car around to 6 shops today.. 5 of them had their heads up their asses and had NO clue.. said it was a loose mount.. i told them to check them.. they did.. all spec'd EXACTLY as they should be. the last and final shop i took it to had PERFECT knowledge of what was going on.
i walked in, he said take me for a ride, i got 2 blocks away and he said pull over.. i did, he looked under the car and said.. you need OEM axles dude... they explained it to me what the diff was, and showed me a set... And now i have some on the way to me
ill let you all know if this solves the issue. Im getting a set of used OEM ones.. i pray they are in OK condition.. if not.. good cores at least LOL.. or i can maybe slide the dampers off and put em on my new axles
