what is a b18c
  • Thread starter Thread starter b20 lover
  • Replies Replies 16
  • Views Views 12K
b20 lover
i bought a motor for 250 n its a b18c i looked it up n i couldent really find anything out on it i wanna no if its worth fixing
Wow. Have you tried searching around the site first of all? Second, why would you buy something if you don't know what it is? I will probably be the "not so harsh" person on here when I tell you that you should do your research first. I'm really shocked that you don't know what a GSR motor is.
It is a very good engine. What is wrong with it that you would need to "fix" per say?
Good point. Does it have a number after the C? Perhaps it is a B18C, B18C 1 or B18C5?
Dude that motor is worthless. It's junk. You don't want it. It only makes like 70 horsepower and even less for torque...
Tell you what, I'll buy that horrible piece of crap off of you for $300. That way you can make some money off of it. Sound like a deal? :D
HAHA! Damn it man! You're on a roll today and I can't rep you. hahaha!
Lmao. Thats one hell of an offer for a boat anchor like that, the OP should deffinitly take that deal! :)
yeah I got an engine in my civic, It says 2jz on the engine code and it has these 2 little snail things with air filters on them. I bought the 2000 civic ex coupe like this for 2500. Is this good?
You're a retard kid. It took you longer to register with hondaswap than it would if you woulda googled b18c engine.
[edit] B18C
  • VTEC
  • Found in:
    • JDM Honda Integra SiR-G
      • Power: 180 hp (130 kW) @ 7,600 rpm
      • Rev-limit: 8,200 rpm
      • 126 ft·lbf (171 N·m) @ 6,200 rpm
      • Transmission Type: 4-speed auto transaxle or 5-speed manual transaxle with optional LSD
      • Displacement: 1797 cc
      • Compression: 10.6:1
      • Bore: 81 mm (3.189")
      • Stroke: 87.2 mm (3.433")
      • Rod Length: 137.9 mm (5.429")
      • Rod/Stroke Ratio: 1.58
      • Transmission: S80, Y80, S80 w/LSD, Y80 w/LSD
    • JDM Honda Integra Type R
      • Power: 200 hp (150 kW) @ 8,200 rpm
      • Rev-limit: 8,900 rpm
      • 134 ft·lbf (182 N·m) @ 7,300 rpm
      • Transmission Type: 5-speed standard with LSD
      • Compression:y 11.1:1
      • Bore: 81 mm (3ft")
      • Transmission: J4D (96specR w/ LSD)N3E (98specR w/LSD)
[edit] B18C1
  • VTEC
  • Found in:
    • 1994-2001 Honda/Acura Integra GS-R (DC2 & DB8)
      • Compression: 10.0:1
      • Redline:8,000rpm
      • Power: 170 hp (127 kW) @ 7600 rpm & 128 ft·lbf (173 N·m) @ 6200 rpm
      • Transmission: Y80 yes
[edit] B18C2
  • VTEC
  • Found in:
    • 1994-1999 Honda Integra VTi-R
    • AUDM Spec 1993-1999 Honda Integra VTi-R
      • Power: 167 hp (125 kW) @ 7600 rpm
      • Torque: 128 ft·lbf (175 N·m) @ 6200 rpm
      • Redline: 8200 rpm
      • Fuel Cut: 8300 rpm
      • Transmission: Y80 (No LSD) 5-Speed Manual Transaxle
      • 0/100km/h : <7.3 seconds
[edit] B18C3
  • VTEC
  • Found in:
  • Power: 193 PS/189 hp (141 kW) @ 8200 rpm & 127 ft·lbf/172 N·m @ 7500 rpm
[edit] B18C4
  • VTEC
  • Found in:
    • 1996-2000 UK Civic 1.8i VTi 5-door Hatch
    • 1996-2000 UK Civic Aerodeck 1.8i VTi 5-door Wagon
    • 1998-1999 EU Civic Aerodeck 1.8i VTi 5-door Wagon
    • 1998-1999 EU Civic 1.8i VTi 5-door Hatch
  • Power: 169 hp (124 kW) @ 7600 rpm & 117 ft·lbf (158 N·m) @ 6200 rpm
  • Limit: 8200 rpm
  • Transmission: S9B w/ LSD.
  • 0/100km/h : 8.3 seconds (8.8 Aerodeck)
[edit] B18C5
  • VTEC
  • Found in: USDM DC2 Acura Integra Type-R (Integra Type-R)
    • 1997-2001 Integra Type-R (**Note: This model was not produced for the 1999 production year)
  • Transmission: S80 w/LSD
[edit] B18C6
  • VTEC
  • Found in:
  • Type: 1.8 litre 16v DOHC 4 cylinder in-line
  • Compression: 11.1:1
  • Air intake diameter: 62 mm
  • Power: 190 PS/139 kW/187 hp (SAE net hp) (139 kW) @ 7900 rpm & 131 ft·lbf/178 N·m @ 7300 rpm
  • Red-line: 9000 rpm
[edit] B18C7
  • VTEC
  • Found in:
^Epic pwnage.
Some people can't even use Google now. How sad.
What the hell is wrong with it? $250? Thats ridiculously cheap. Unless its just a block, or something.
^Epic pwnage.
*in Homer's voice* Google? GOOGLE?!?!? What is dees Google you speak of? :eek:
Damn Brutal
Only if everyone would have just played along with you...lol
^Epic pwnage.
^WERD
$250??..uh, are you sure it hasn't seized, cracked or both, if so you prob just paid for the scrap metal.
what did the seller say was wrong with it that it needs fixing?
I think this guy fell in a hole or somethings...come on man answer the damn questions!
