b18c1 build up
  • Thread starter Thread starter garyeboy
  • Replies Replies 6
  • Views Views 2K
garyeboy
will the head off of a b16a2 work on a gsr block b18c1
if you put that head on u actually get more hp. you can actually build what they call a poor mans type r. which is a a b18 with a b16 head. a b16 head flows more air than a b18 head
FALSE. The GSR and B16 heads have verry similar flow numbers. You can make the same amount of power with either head.
TRUE. The B16 head will lower compression, which is not what you want with an all motor setup.
this is going for a turbo setup, how much does it lower the compression to does anyone know?
