b18a1 in crx si
  • Thread starter Thread starter INJEN78
  • Replies Replies 5
  • Views Views 980
INJEN78
HS LEGEND
cant get it to kick on,have fuel,spark,checked the timing,all the marks lineup,(do i have to check anything with compression stroke?)the motor ran in my civic hatch,now it wont run in te crx,redid all the gorunds,just wont start,itll turn over nice though:D
yea its all fine,just wont turn over,the gas is a little old,but that shouldnt cause it to not start
have you checked your fuel pressure? fuel filter?
If you think your spark is good, get a can of ether, remove the intake and have a buddy start the car while you spray the ether in the thottle body.
Worked for my car. Worth a try. And if it doesn't start the car, it will give you the opportunity to use the rest of the can as a torch and burn stuff to take out your frustration. It's a win-win!
