What about the guy who told me I need to put 1000 miles on my motor before I tune it and that I need to "break it in"? I will be blunt. That person is not educated on motors. With 1 exception...if that person told you to DYNO your motor at narrow throttle, that your going to be driving it for a few hundred miles, that's fine... However...I see a lot of people that customers "think" are smart and they are recommending 1000 mile break ins on built motors! That is the stupidest thing you could possibly do! When you hear terms like this, BEWARE and RUN THE OTHER WAY, or CLOSE YOUR EYES: "Just put in a base map, and break it in for xxxx miles, then go tune it, give the rings time to seat.." RUN!! CLOSE YOUR EYES! That is insane, stupid and ignorant all at the same time. Base Map? What the heck is that? When Honda tells you to put xxxx miles on your motor, or whatever, its completely tuned already with great air fuel ratio's. Do don't think for one second your base map is worth a damn, because it is a shot in the dark. It sucks UNLESS you went to a dyno and fully tuned your car at the RPM's and throttle position your driving it at with a wideband hooked up to the car. That chip your using is somebody's educated guess at what will run the car. Its not intended to drive on for any extended periods of time on! (I HOPE THEY TOLD YOU THIS, if they didn't... RUN!!) If you have no other option, a basemap can be used for getting your car a FEW miles straight to the dyno, but I am very against that even and a tow truck would be better.. This is a theme you all need to understand: "Don't start your motor unless you can adjust the air/fuel ratio to a reasonable number right away". Anything else is unwise, and foolish. Wideband cost like $350 shipped, just buy one for you and all your buddies to share. Best money you ever spent.
