rkwoos12
hey guys im still haveing a problem when i start the car when cold it will idle a little high like 1500 sometimes 2000 rpm then it will go down when warm but after i drive it and i stop the idle starts to go up and down, i took the fast idle thermo valve off and took it apart and cleaned it and it help for a little bit
i tested it by the manual and im geting little sucktion on lower port the manual says there should be no sucktion at all on lower port when warm could it still be my fast idle thermo valve causeing this problem or would it be the electronic air control valve? let me know what you guys think
