battery light problem
  • Thread starter Thread starter rkwoos12
  • Replies Replies 23
  • Views Views 3K
rkwoos12
hey guys i finaly got rid of all my cels but i still have one last problem with my battery light i dont know how to fix this either i got a good battery and the Alternator if for a 92 accord and it charges good but its in my 94 honda civic ex would this cause the battery light?
It might, have you had the battery/alternator checked to make sure they are working correctly. Also are you sure you have everything plugged in like the sensor that controls the light.
Sometimes the Light comes on when you - Terminal is lose, trigh tighting it, once happend to me, then it shut off.. :)
That could be, u could be over charging the Batt, :(, i dunno, but look up the specs between the Civic and Acord, im sure the acord has a bigger better alt then the civic :(
ok thats what i was thinking also, im probably gona go to a junk yard see if i cant trade for a civic alt thanks alot ill let you know what happens
Ya I went to my freinds car today, The Acord stock depending on what year puts out alot more, but He has 1 in his civic, then again he Has a sound system that drains his bat and puts alot of stress on his alt, so he needed a bigger 1 :)
96 and up Civics come with a 75 amp alternator while the accord equivalent come with an 80 amper. And the green plug on the back of it, is it pinned the same way as the Civic? But the difference in amperage would cause the ECU to believe that it's overcharging the battery, which it kinda is. I would swap it out and see, but beware of junk yard parts. it's asking for problems with that kind of part.
ok thank for your help.
