b18b1_delsol
Okay so to continue from another thread that got out of hand....
So I am going from a obd1 non vtec motor to a obd2 vtec motor. The car is a 94 del sol si which org had a d16z6. Do I have to run a crank sensor since I will be converting to obd1 or can i just unbolt and discard it? I already have a dizzy harness that converts from odb2 dizzy to obd1 dizzy harness. Shouldn't I just be able to run a man made vtec sub harness to solve the vtec the situation or will that not work? Will someone just set me straight about this wiring situation?
Thanks
[/endthread]
