90 accord h22 swap
93jdmegtc
my boy is doing a h22 swap what will i need to do ..
can i used the axles
the wiring harness
and the motor mounts ..>?
if you keep the same transmission you do not have to change axles.
H/F series are very interchangeable. I don't remember whats in the 90 accords. if its not an F you will be needing more things than what i list
Basically, complete longblock,ecu, and jumper harness or to rewire it to the engine OBD, which will either be OBD1 or OBD2. Double check some write ups to your chassis code to find out all the odds and ends.
this is correct, even if you change to a H23 or H22 transmission, You still keep the same axles(midshaft, as long as they are good to go.
as far as motor mounts. ESP has great ones, they even have them if your going automatic to 5spd swap(if this is the case you need to get a different transmission mount but ESP sells them, look for "CB" car model.)
Explicit Speed Performance
also check out www.cb7tuner.com
tons of information in the swap thread.
I have done several swaps, lemme know if you need anything!
good luck!
You will use your stock accord harness on the H22, replace what you need to, but the axle setup should work fine. Read my guide.
