91civicstd
I heard i could use the si dist and ecu to run the d16y8, then wire vtec to a switch.
Is this true?
Is this true?
Also,what exactly would i need to go obd1?
So to run obd 1 the y8 dizzy will be ok?to above question, no the y8 dizzy will not work with a pm6.
to run obd1 you'll need a p28, obd0-1 jumpter w/ subharness, and a 4-wire o2 sensor
Aslo, what would i need to convert to obd 2?
