That only applies to 'light ray' heat? i feel dumb lol... Does hondata make heatsheild IM gasket for the LS motors? If so, get one. It's well worth the $50What you are thinking about is color soaking heat from the sunlight. The IM being out of sunlight won't be affected by the color. The turbo isn't going on yet and when/if it does it's going to be low PSI.
That only applies to 'light ray' heat? i feel dumb lol... Does hondata make heatsheild IM gasket for the LS motors? If so, get one. It's well worth the $50I had one on my B16 and after a half hour of driving I could literally rest my hand on the IM. You're never able to do that with the OEM paper gasket
EDIT: Hondata does make one... Heatshield
Cool thanks for the info I will look into that when I change out the IM and maybe put the turbo on.
Sorry I haven't updated this in a while but I got the car finished. Tuned at 237 hp. It ran and drove great. I sold it yesterday so now it's time to look for a new project.
reading > youdid this guy ever finish this project??
Ok guys id just like to throw this out as im curious whether anyone on here has ever successfully completed an Integra Type R 96 spec swap into an ef. Im thinking about a build that may just work using the complete 96spec suspension, transmission and engine into the ef .What im worried and curious about is the harness and electrical connections. Im weel into the idea of just simply popping on, possibly a 3' to 5' tachometer on the dash and using a ITR exhaust system aftermarket down to the test pipe then run the rest..Any information or possible feedback from someone who has pursued this sort of build would be appreciated this for me is fresh and ive never done a swap like this before...Questions : does the idea of using the entire ITR suspesion make sense and will it fit without complications.?
what are the possible wiring issues which may occur.?
given the b series set up will the b18c engine fit with out adjusting the mounts etc..
