Back on the ground...
  • Thread starter Thread starter Airjockie
  • Replies Replies 75
  • Views Views 13K
Airjockie
Watanabe Whore!!!
Rest In Peace
Off the jack stands finally, and outside to let the rain wash off the dust...
and larger pics here... Another 260Z
74 260Z
Fresh rebuild....
5 speed swap
new reverse switch
ACT HD pressure plate
ACT 6 puck Disk
New Clutch Slave cylinder
New Stainless steel flexible Slave hose.
Nismo 2 way LSD
R180 diff 4.11
Rear disk brake swap
JSK Rear Disk Brake brackets.
fresh disks.
New Hawk rear pads
Rebuilt 240SX calipers
JSK 270mm Wheel spacers
ST huge sway bar
Tokico Illumina's
ST 1" drop springs
Larger front brakes swap
Toyota 4X4 calipers
fresh cross-drilled and slotted rotors
fresh Pads
New 15/16 Master Cylinder
JSK 270mm Wheel Spacers
ST huge sway bar
Tokico Illumina's
ST 1" drop springs
Wheels:
17x7 17x8 Volk Racing Ultra C's
215/45 225/45 Falken 512's
Still left to install:
New Fuel System
Triple Weber 45mm Carbs
New Canon Intake.
New Carter Fuel pump.
New Fuel filter.
New throttle linkage.
Fresh MSD 6AL
Roll bar
Race seats and harness.
Interior.
are you still working on doing the rb swap?
In the fall, when the snow start's, the car will go on the rotis, and get fully rebuilt with more awesome parts... RB, Cage, widebody, new frame rails, sick welding parts, sick wheels, and everything my next year's income tax return can afford...which will be around $7000:ph34r:
For now, I just want a fun DD and summer car...:p
when'd you get the other 2 volk's?
That was a set that I snagged last year that nobody wanted to buy..
I'm still looking for a pair of 17x9 CE-28's to match the othe rpair I have...
i wanted to buy the volks. they dont fit over my brakes though.
you only know that the mirage is that pattern because i told you yesterday ;)
Nah, I knew it was the Mirage pattern from a long time ago, you always complain that he doesn't have any mirage sized wheels.
It's also the pattern for the 4-lug BMWs.
nope, wrong!
the OEM mirage bolt pattern from 93-02 is 4x100. only the 89-92 is 4x114
front hubs are 4x114 EVO3 and rear hubs are 4x114 GVR4. yes, lots of combinations of parts on the car ;)
