Clutch pedal squeaks
  • Thread starter Thread starter fionntan
  • Replies Replies 14
  • Views Views 4K
fionntan
Banned
My clutch pedal has started to squeak when letting it out. Does anyone know what I need to lubricate to fix the problem?
I would try the spring and whatever else moves when you let off the pedal. Some times factory grease doesn't last forever.
93 civic has hydrolic master cylinder. Shaft that pushes fluid can get squeaky. Mine squeaks and its brand new (non-OEM so you get what you pay for). You might be able to spray some silicone lubricant on the shaft and see
The clutch master cylinder is in the engine bay correct? The noise is coming from inside the cab. I will try the silicone grease first and see if that works.
the clutch MS is in the cab and the engine bay.....both
Mine has been squeaking as well, I'm gonna have to see if I can get some lube this weekend, I may even venture as far as to change my oil again.
