worth 3000?? yes or no
  • Thread starter Thread starter Rjs4490
  • Replies Replies 41
  • Views Views 5K
Rjs4490
93 honda civic vx hatch.
built lsvtec
95 b18b1 block
oem honda pr3 b16 pistons 11:5.1 comp.
oem honda piston rings
arp rod bolts
oem honda crank and rod bearings
type r oil pump
gsr water pump
gsr timing belt
oem honda headgasket.
hondata intake mani gasket
p30 b16 intake manifold
dc sports race header with 2.5 inch collector
2.5 inch exhaust with 2.5" vibrant muffler
golden eagle lsvtec kit
99 b16 head
supertech valve springs and retainers
gsr cams
gsr trans with act clutch
chipped p28 ecu
with cams and a tune car will easily go low 13's. as of right now best time is 13.9 on bf drag radials.
its captiva blue with a new front end. so the front is black. has a dent and small rust on driver side quarter panel. other than that its clean. rides smooth. stock suspension in the back with coilovers up front. real jdm headlights with jdm corners. ek yellow fog lights. cf duckbill.
gsr rear cloth seats and integra ls cloth front seats. clean black interior. 226k on the shell. clean title. comes with steelies and hub caps with brand new tires.
sounds good to me. if the body's in decent condition (ie nothing major) i might even go as high as something like 3500 for that car. If it's got body damage (or seams ripping on the edge of the seats) id start at about 2500 see if you can haggle him from there.
Depends on who you ask... I wouldn't pay 3k for someone elses build unless I know who put it together. That's just me though...
*update*
I appreciate all the feedback but the car has engine has only 5000 miles on it!!
Who built the motor? Was it someone reputable or was it someone who may have not sized the correct bearings or gotten the ring gap right? Go through that thing with a fine tooth comb. Ask him to compression test it. Look for smoking when you're driving it hard. I know people who have bought cars with built motors and then gotten effed a month down the road when the rod bearings went out.
Wurdd... you should get some pics for us too! :ph34r:
I'll second that. Make damn sure the title is clean and there is no funny business and snatch that biatch up.
pop off the valve cover and see if it dose have the springs and retainers, Also ask what is he runing as a map? because with a 11.5 CR + stock ecu+ drag racing = boom!
If all checks out, get that bitch! looks like a nice DD
I would ask why the front end was replaced, and take if for a test drive. Make sure you "open it up" a few times to make sure the motor seems healthy. But it seems like its worth 3k.
Check out the core support area. Looks as if it has been in a front end collision. Check to make sure everything lines up decent in the front end, I'd be a little sketchy about that buy. On the plus side, it is only 3k and the engine alone is worth that provided it was assembled correctly.
tell him you want the wheels too....it only comes with steelies.
built lsvtec
95 b18b1 block
arp rod bolts
type r oil pump
gsr water pump
gsr timing belt
99 b16 head
gsr cams
chipped p28 ecu
wonder why it has a new front end hmmmm.... i'd definatly test drive it first then if it drives good its worth it, go for bro!!!
I BOUGHT THE CAR....imports wars!!!!!..lol..
The kid i bought the car from ran it at the track and he ran 13.9...i have the slip...he wiegh's 300 pounds...i wiegh 150 lol...im going to skunk 2 the shit out of the car and run low to high 12's..then turbo =)...who knows what ill run lol
thats about what i run in my civic right now with this h22a1 , but deal on that ride bro....:D
