<br />bseries turbo..
<br />
<br />
X2?? Wats that
<br />oh yeah without a doubt a b-series either all motor or boosted would blow away a lot of cars just because or the tune and power to weight ratio. it also depends on how you build it, because if you just slap a turbo on it and call it a day you would pop the engine like it's your job, but if you actualy take the time to build it and tune it, it'll be one bad car
<br />Slam the compression way down first, then build it.
That motor is in the 11:1 compression ratio range when you want it in the 8.5:1 range, maybe higher but not much.
<br />Wtf is with the "<br />"?<br />
<br />
Anyway you need low compression pistons. That motor is in the 11:1 compression ratio range when you want it in the 8.5:1 range, maybe higher but not much.<br />
<br />
What you need to really do is a shit load of researching and reading. Search Google for turbo, building a motor for turbo and tuneing, tuneing, tuneing...the most important part of a turbo build.
Ahh shit, I was thinking of the JDM B18C version. I assumed it was JDM because he didn't say "B1".hahaha.. what??!?
a b18b is in the 9.2:1 range.. lol..
b16s dont even have that high of compression ratio..
