Hey guys hows it going I just recently traded my K24A4 for a full H22A swap out of an EG.
The parts I have are:
- JDM H22A (its stamped FIEND next to the H22A and below it, from the research I did its a guy or shop in california that seem to do engine work)
- Port and polished head (haven't verified yet since the IM is still on the back and exhaust ports are WAY dirty)
- 440 RC injectors - FPR
- Skunk 2 cam gears
- Megan header
- Clutch - Shifter cables
- Harness - P28 ecu
- Clutchline - Axles
- Mounts are for an EG
From what I've read here:
[FAQ] H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here
Gathering EK B-series wiring information
ECU Pinouts
What I SHOULD need to complete the swap are these hasport mounts HERE and this jumper harness listed HERE if Ive read right and am correct. I do have a DX so I'm going to need to add wires I know, my question is since this is my first swap and am new to hondas. How difficult is it truly to add the VTEC line wires etc, would I be better off purchasing a 98-00 SI/EX harness or is it not worth the expense? Also will the axles I've acquired work with the EK chassis or are they the wrong size also.
Few more if you'll bare with me. Will the clutch line fit as well, and in the pictures below what are the 3/4 rectangle looking fitting next to the shifter adapter there are 4 of them just loose in there.
I believe thats all the bases I need to touch and still have questions on i'll include pictures of everything I have below if it can help any of you decide whether or not it will work.
I appreciate any and all input or help that you could add or pass on to me!
Onto the pics:
Thanks again for any help!!!
:thankyousigna2:
- Skunk 2 cam gears
- Megan header
- Harness - P28 ecu
ECU Pinouts
Onto the pics:
