b18 crx will get fuel but no fire
  • Thread starter Thread starter londoncrx
  • Replies Replies 10
  • Views Views 2K
londoncrx
so i had a cut engine harness so i replaced it with another harness outta si as far as i can see everything is hooked up all the fuses are good but still no fire and the ecu ground is hooked up
was your car originally an si? because if not then it wouldn't work. like if you had a dx and used an si harness it wouldn't work
it ran fine before i shut it off and no i didnt mess with the dizzy after i shut it off but it has a b18 mpfi and yes it is a dx but it will work an si engine harness is what i took out of it
The thing is I was always told that your engine harness has to match your interior harness. so I think you would have to get another dx harness and either convert that to mpfi or buy an already converted harness
