im pretty sure u just gave me some tools i need to grab, so exactly wat do i need to basically rebuild a head.??.by removing valve springs, retainer, valves, and anything else im suppose to take out and replace since im in there.
another Qs, i already remove the cam holder thingy and the cams wit gears still attach so wen i try to see if it would sit bakk in rite, the cams wouldnt sit rite wit both the "UP" on the gears pointing up.....so i spin it alittle and they sit good but wen i chekk the gears, EXH side facing up but more towards the left, and INT side facing up but more towards the right so its basically making a Y, dont kno if dat make any sence but wat u think about that, do i need to get both the cam gears to face directly UP wen i bolt down the cam holder..
lol..another Qs wat u call that thing that u can easily pull off and is on top of the valve springs?, if i take em all off, do i need to make sure they all go bakk where they came from or it doesnt matter where, they all da same not like the cam holder thingy where they need to be put bakk on the same spot where i take it out from.,. can i spray chemical inside my head under the valve cover and then clean it wit water and soap or something, or its not good to spray anything in ur head?....i should get a manual first before i start
.....thanks!
