im not sure if i like it. commoditization of information and knowledge.
Oh sweet...
First thing that comes to mind:
Handbrake (the video formatting software) doesn't let you convert multiple files at once. If you have 200 files you want to convert into another format, you have to select them one at a freaking time to add them to the processing queue. It's a philosophical decision, not a design limitation. The devs argue that every file is different; you can't possibly want to convert multiple files into the exact same format with the same settings. Dozens of people have asked for the feature on the forums, they just berate them, and lock the topic.
I have a camera that creates a separate file every time you press the record button... I have hundreds of files to convert with the exact same settings, and really need to ability to just ctrl-click all of them and convert.
Fortunately it's open source! It's in C#, found a guy on Fiverr who will do small work... Can't be much to change the file dialog to accept multiple files, loop through them and add them to the file queue with the current settings.
hehehe :search:
There it is. I can't find the emoticon panel in the reply box anymore.
its not on the quick reply box
you need to go to the advanced view... then there is a box to the right with smilies and a "more" link that will bring up all of them
